brake proportioning valve problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2009, 05:35 AM
My '79 Suburban has started leaking brake fluid from the black thing on the fitting on the right side of this valve (goes to the rear brakes). A little rubber thing and something that looks like a star washer ~1/4" in diameter came out of the hole. I can't find another valve around here, not even at a Chevy dealer, and I don't really want to get a used one. I need to get the truck back on the road ASAP, and this thing has got me stumped. Does anybody know what that black thing is, and if it would hurt anything if I just plugged the hole with something?
Old 02-18-2009, 12:09 PM
The black rubber part is a boot that covers the pin that is supposed to be pressed in when you bleed the brakes. The pin usually has o-rings on it. I'm not sure you you would plan to plug it, since there are no threads there. A used valve will be fine for the short term. You can also try to remove the pin and replace the o-rings.
Old 02-22-2009, 02:35 AM
It's not the one on the end (left side in the pic), it's the one near the right side of the pic, seen just below the upper bolt hole.
Old 02-22-2009, 08:25 AM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Not sure if this will help but I found a website that kinda shows the internals. I'm getting ready to install one in my project and ran across it while looking for instructions.
http:http://www.mbmbrakeboosters.com/F.A....ng-Valves.html
Hope this helps
Mike
Brakes that don't brake KONADOK Suspension - Brakes - Steering 45 04-10-2015 05:01 AM
Brake proportioning valve problem. ck 2 Suspension - Brakes - Steering 5 09-30-2008 10:38 PM
60 Impala Brake Light Problem Strifex Electrical 1 08-07-2008 10:10 PM
plug / valve problem...again Speakrdude Engine 18 05-30-2007 02:00 PM
Porportioning valve and brake switch mounting DDGETHS Suspension - Brakes - Steering 7 02-18-2005 01:51 PM
