Brake question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-20-2004, 10:15 AM
Mooshaker's Avatar
Brake question
I cannot get the brakes to work properly on my 34 ford.
Details
New car with all new parts
Corvette master cyl 1" bore (Bench Bled) mounted on firewall
4 Wheel Disc GM Calipers
2# Wilwood residual valves mounted within 3" of MC
Dot 5 (Silicone brake fluid)
If I pump the petal 8 or 9 times I get good brakes that are not spongy. Soon after letting off the brake petal, the pads on the left rear wheel are loose. I can move the inside pad with my fingers.
Could the problem be that the residual valve is defective? The valve appears to be installed correctly as the MC side is toward the Master cylinder.
Any ideas?
Ron
