Brake Rotor advice please - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-05-2010, 01:16 PM
I have a 69 camaro with factory front Discs, I am looking for a pair of Drilled/slotted Rotors for the front discs that are good quality and will not rust.
I do not race this car, but instead looking for looks and some decent performance to help braking if I do need it.
I am looking on e-bay but do not know what brand works well.
Any suggestions on who to use or who to stay away from...remember NO RUST!!
Thanks a bunch
Old 04-05-2010, 05:07 PM
Wiki Edits: 31
IMO, on a street car, Drilled and slotted rotors are not good.. they cool the best, but they are also weaker than a solid rotor, being there full of holes.. I'v seen many pairs with haze cracking going from hole to hole.. use just a slotted rotor.. summit racing as well as Jegs probably list somthing
your not going to stop rust with any brand. just drive the car and that'll keep the rotor as rust free as your going to get.. you could also tape off the braking surface and spray them with a high temp paint to keep the hub from rusting.
Old 04-05-2010, 07:47 PM
327NUT's Avatar
I agree with Matt to a degree, they can crack if...they are cheap "offshore" junk and/or you drill the holes too close and you really over heat them. It seems like some guys want to make their rotors look like swiss cheese. I made a template and drilled my rotors (1/4") for my '32, came out pretty nice, need a drill press to do it.
You have to remember to flip the template over for left and right as the rotors are now directional due to the way the holes flow away from the hub. Then you lightly countersink the holes which helps greatly for a no crack life. I left exactly 1/2" of material between the edges of the countersink. They also sell them on ebay, make sure its a long term seller with good feed back....OR you can google "drilled and slotted rotors" lots of places.
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 05:15 AM
Advices on brake system repair 78 Monte rack Suspension - Brakes - Steering 5 01-12-2009 08:32 AM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
