brake rotor search - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-06-2007, 03:40 PM
chevyhotrod's Avatar
brake rotor search
For my rod i need new front brake rotors. I am told that i have an malibu frontclip. But the age of the front is not sure. It could be 1977 to 1981.
does anyone know how i can find out what rotors i need?
Thanks
Arnold
Old 06-07-2007, 04:05 PM
cboy's Avatar
Last journal entry: Finished
Arnold,
I'm not sure this would work since I've never had to do it but there should be a number stamped or printed on your bearings. If this number hasn't been wiped out by wear, you might be able to trace that number backwards at a "cooperative" auto parts store to find the makes/years that rotor& bearing combo was used on.
Always learning...and sharing what I've learned.
Old 06-08-2007, 09:41 AM
I looked on the bearings but the number isn't readable.
I measured the bearings and according to that i still can't find the right disks.
If I look at rock auto for the bearings on a camaro and a malibu, they are the same. If I look at the same cars for the disks than they are different. So that won't help me.
Arnold
Old 06-09-2007, 07:49 AM
Look at the caliper. After about 78 GM switched to the Metric front end on their B bodies.
Here is a picture of the metric caliper. If yours doesn't look like this then you have the older front end. If you do have a metric, just get rotors for the 81 and they should fit.
Old 06-09-2007, 07:50 AM
Here is a pic of the older style caliper.
Old 06-10-2007, 12:17 AM
Chopt 48's Avatar
There are only about 3 basic Chevelle style rotors. The 72 and earlier, the 73/78 and the 79 and up rear wheel drive.
That pretty well limits the choices when you carry one into the parts house and set it on the counter and say "I need two like this".
There are some distinct differences in the rotors.
The 72 style has a very short hub sticking out as compared to the later units.
Do the spindles have removable steering arms or are the steering arms cast into the spindles? 72 and earlier had bolt on arms, 73 and later had the arms cast into the spindles.
http://www.partsamerica.com/ProductL...r=Disc%2fRotor
you can compare the photo to your rotor. If that doesn't match put in 1975 chevelle Or Malabu
By comparing the photos you should have a better idea of what you have. Then you can bop on down to the parts house. Armed with a print out of the page to help get a better price.
the main link is www.partsamerica.com
Old 06-10-2007, 12:37 AM
I think they also went to a larger outer wheel bearing in '78 or '79.
Old 06-10-2007, 11:19 AM
I indeed have a larger outer bearing.
Tomorrow i will look to see if i have metric calipers. I do think so because the bleeders are metric.
Old 06-10-2007, 11:34 AM
Chopt 48's Avatar
The 78 and earlier hubs use the BCA A2 outer bearing sets the 79 and later use the BCA A3 outer bearing sets. It looks like they all use the A6 inner bearing sets. Set meaning race and cone packaged together.
Old 06-11-2007, 12:46 PM
Today i looked to see if i could find some more information.
these are the pictures i took.
I indeed have the bca a3 bearings.
It looks like i have the metric calipers also, i am getting close.
Old 06-11-2007, 01:34 PM
Chopt 48's Avatar
I believe you have it nailed. They should be 79 and up. Take one of the rotors in for show and tell at the parts counter and you should be in business. I even spotted some hot lick drilled and slotted ones if that hits your fancy.
Old 06-12-2007, 08:39 PM
www.partsamerica.com shows a different rotor for '82-'88 G-bodies versus '79-'81. They do not say what the difference is.
Anybody know if the markings on the wheel mounting flange of his rotor mean anything?
Old 06-12-2007, 08:42 PM
Chopt 48's Avatar
That makes it Time for show and tell at his favorite parts emporium then.
Now that it looks like it is down to either/or.
Ford Galaxie Disc Brake Conversion CrashFarmer2 Suspension - Brakes - Steering 5 04-10-2010 04:52 PM
It's a Mustang II, but what's in it? And a brake problem . . . hduff Suspension - Brakes - Steering 4 11-19-2006 06:00 PM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
