Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - brake rotor search
Old 06-07-2007, 04:05 PM
cboy's Avatar
cboy cboy is offline
Last journal entry: Finished
Arnold,
I'm not sure this would work since I've never had to do it but there should be a number stamped or printed on your bearings. If this number hasn't been wiped out by wear, you might be able to trace that number backwards at a "cooperative" auto parts store to find the makes/years that rotor& bearing combo was used on.
Always learning...and sharing what I've learned.
