brake set-up/rat rod - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2009, 08:44 AM
Here we go! Iv'e got all the parts, how do I install them?
o.k. here's what I have/ 2psi residual valve a 10 psi for the
back and a adjustable proportioning block. Once I get all
the fittings together I'll need you guys to help me put it
together. any pics? That would be awesome. Thanx
Old 05-11-2009, 12:08 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
try this: http://www.mpbrakes.com/uploads/prod...l%20valves.pdf
Old 05-11-2009, 12:18 PM
Wiki Edits: 647
or: http://www.mpbrakes.com/uploads/docu...Brakepedal.pdf
Old 05-12-2009, 09:09 PM
rwruther's Avatar
Last journal entry: new wires for the hot rod 39
http://www.piratejack.net/Tech-Suppo...gurations.html
This Pirate Jack guy has bunch a stuff that helped me. I had trouble getting the leaks stopped....crummy double flare tool from Summit...Us expensive tool for the flares for no leaks or just have to do it over I guess! Good luck
Old 05-13-2009, 08:30 PM
Cape Cod Bob's Avatar
order mp brakes catalog. H as a great print in it of variations of brake setups.
383 vs 350 TheCiscoKid Engine 86 05-03-2008 04:10 PM
327 in 88 Truck pete379 Engine 101 01-19-2006 10:03 PM
Rod ratio RobbieRat Engine 16 11-29-2005 07:52 PM
brake question Ratoflic Suspension - Brakes - Steering 1 09-29-2005 11:32 AM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 07:17 AM
