Brake/signal light question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2009, 06:19 PM
This may sound like a dumb question,but here goes.How do you hook up the brake/signal light wires where when the signal is turned on it cancels the brake light and flashes?I did this a long time ago but I forgot. Any help appreciated. Thanks...Frank
Old 09-14-2009, 08:54 PM
Wiki Edits: 27
T I Brakes
The wire goes from the brake lite switch to the column turn signal switch. Normally both brake lites work. when you flip the turn switch it shuts off brake lite power to one side and connects that wire to the turn signal system.
Light switch question.. APalusky Electrical 9 07-14-2009 07:52 PM
Timing Light Question Regal Beagle Engine 6 09-04-2008 07:55 AM
Trust the timing light or the timing pointer? lluciano77 Engine 6 03-06-2004 01:35 AM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 10:25 AM
Tail light question Jag Daddy Body - Exterior 0 09-01-2003 01:34 AM
