Brake squeal problem!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2007, 08:58 PM
Last journal entry: Latest picture
I have about 2000 miles on my street rod now, and the brakes are starting to squeal. I'm using Wilwood Billet Dynalite caliper on all 4 corners, with non-vented discs in the rear. Are there any tricks to keeping these quiet? I think it's only the rears making noise but it's hard to tell.I've heard of shims that are available, but I'm not sure if they are available for these calipers. Thanks, Dan
www.geocities.com/dantechfab
Old 07-27-2007, 10:50 PM
They do make or atleast used to a spread on and a spray on type of anti squeal stuff it goes between the caliper piston and the pad ive never had a brake squeal using this stuff. The reason im not sure if they still have this stuff is because alot of manufactures started putting a shim on there pads so the market may have dried up. But if its out there yet this stuff works well.
Old 07-28-2007, 03:05 PM
techinspector1's Avatar
Wiki Edits: 326
I use wheel bearing grease. It's specially formulated not to run when it gets hot. Hold a match up to a blob of it on the tip of a screwdriver and see. It won't run, stays put and dampens the vibrations which cause the squeal.
It's a Mustang II, but what's in it? And a brake problem . . . hduff Suspension - Brakes - Steering 4 11-19-2006 06:00 PM
Brake problem?? cabrio Suspension - Brakes - Steering 2 05-14-2006 05:52 PM
74 Corvette Brake Problem iniguy Suspension - Brakes - Steering 7 07-02-2005 04:46 PM
Chevy Cavalier Disc Brake Problem oldschoolrods Suspension - Brakes - Steering 10 03-14-2004 09:16 AM
brake booster vacuum problem spankthru Engine 1 06-18-2003 07:57 PM
