-   -   Brake Swap (http://www.hotrodders.com/forum/brake-swap-12515.html)
novachad 01-22-2003 08:34 AM
Brake Swap
My 72 Nova has all wheel drum brakes. I found a 71 firebird that has disk on the front and i was wondering what i needed to do 2 swap these. <img src="confused.gif" border="0">
zonk 01-22-2003 09:16 AM
go to page 3 about 69-72 nova brake swap
novachad 01-22-2003 01:04 PM
Thanks but it doesnt say anything about a 71 just 67-69 <img src="confused.gif" border="0">
krangar 02-16-2003 07:48 AM
I have recently converted my 68 nova to disc brakes The spindles I used were off of a 72 chevelle wagon.They worked perfectly,dont know about the firebird.If the firebird is front steer check to see if the steering arms are bolt on,if so the steering arms of of your drums will bolt to the db spindles good luck
krangar 02-16-2003 07:49 AM
ssaza 02-16-2003 08:04 AM
71 camaro/firebird will not work correctly.must be 67=69 camaro or firebird,can use 67-72 chevelle,gto etc. A-body gm cars,switch steering arms,just 2 bolts,swap with your drum brakes steering arms.also nova,apollo,omega, thru 74 will work,
