brake swap on 9" - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2012, 02:48 AM
brake swap on 9"
Just wondering as to how you figure out your brake back space on a new build. And where is the backspace made up in the calipers or in the rotor? Hope that makes sense
Old 04-04-2012, 07:09 AM
35WINDOW's Avatar
Last journal entry: Engine!
I hope I am answering your question here, but the "back space" dimension is from the outermost part of the Axle Housing Flange to the outermost part of the Axle Shaft-this might help:
http://www.wilwood.com/BrakeKits/BrakeKitApp.aspx
As for how they make upthe difference, on my Car (with Wilwoods), it was accomplished with the bracketry that holds the Caliper-
Press brake question: 1/4" plate on a 1" die lowROLLERchevy Garage - Tools 3 06-08-2011 11:47 AM
McGaughys 2" Drop Spindle 13" Brake Kit Conrad_AZ Suspension - Brakes - Steering 0 06-01-2009 11:19 AM
"electric vacuum pump for the brake booster" Joe DA Suspension - Brakes - Steering 19 01-28-2009 09:13 AM
12 " drum brake swap strangecars Suspension - Brakes - Steering 5 01-14-2009 05:49 PM
New here, with 9" Explorer disc brake swap ??? montegoman351 Suspension - Brakes - Steering 6 06-22-2007 04:35 PM
