brake swap takin front discs off 65 t-bird for 64 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2011, 04:10 PM
my 64 t-bird is all around drums and cant stop worth a sh!%. i wanna take the front disc breaks and brake booster and mastercylinder off a 65 t-bird. will this work for me any suggestions?
Old 02-14-2011, 08:25 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
64 to 66 T-Birds are the same body type & the 65 being first year for discs. You need to take everything from the 65, don't forget the proportioning valve, have a look around the 65 to see if anything else is different from what's on the 64.
Rich
Old 02-18-2011, 10:24 AM
found a 65 to look at
Found a 65 to look at but the guy wasnt willing to part with any parts everything looks the same under the hood except the brake booster and the steering gearbox. i got a hold of 65 at a pick a part it was stripped down but i made out with the front dick brakes arms and all. any idea if the steering gearboxs are swapable because the 64"s is huge and wont allow aftermarket full length headers but the 65 will
Old 02-18-2011, 04:30 PM
ericnova72's Avatar
More for Less Racer
The steering box should be swappable but you may need to get all the drag link and tie rods just to be sure, for comparison to your old parts. The steering column attachment may also be different, so you may need the column also.
Blame Ford for changing so many different parts on their cars EVERY dang year, instead of picking a design and sticking with it.
Maverick brake swap With Granada discs foffad62 Suspension - Brakes - Steering 2 01-16-2008 09:54 AM
Valve for Front Discs? Please Help. bigfred1958 Suspension - Brakes - Steering 1 04-10-2006 10:30 AM
spindles on ford disc brake swap for 62 t-bird wildnickels Suspension - Brakes - Steering 3 03-20-2006 04:47 AM
1960 Chevy truck front disc brake swap importeater Suspension - Brakes - Steering 1 07-10-2003 12:16 PM
old caddy new front discs craygunn Suspension - Brakes - Steering 0 10-28-2002 11:29 AM
