Brake Switch Wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-07-2012, 10:40 AM
Brake Switch Wiring
Ok, I've built a kit car that has a steering column with no turn signal switch built in so the turn signals are on separate toggle switches. How do I wire in the brake light switch so the brake lights work corretly? Thanks!
Smokey
Old 06-07-2012, 11:01 AM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Smokey
You will probably have to install diodes in the turn signal wiring to eliminate "back feeding" from the brake light switch. If the turn signals are on seperate toggle switches, you will need two diodes. These will need to be placed somewhere between the brake light and the toggle switches. Once you do that, terminate the wire from the brake light switch "after" the diodes. If you could attach a diagram of what you have, it would be helpful.
Old 06-07-2012, 01:49 PM
I don't have a diagram but think a hot wire to the switch, a wire from the power out to the flasher then from the flasher out to the lights. I see where you're going with the diode, I hadn't thought of that. I bet that's the way I'm gonna have to go.
Old 06-07-2012, 02:50 PM
delawarebill's Avatar
switch..
i ran into the same problem when building my T... used the toggle sw for blinkers.. i also used 2 lites.. amber for sig's and the red for bks.. i got the sig's at a truck stop. ALOT easier to use 2 separate lights.. i think speedway has a signal unit that self cancels.. well someone i know makes them...
Old 06-07-2012, 03:56 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
kiss
The attached drawing shows turn signals in the simplest form.
The scheme uses (2) standard (DPDT) double pole double throw switches, one for each side.
When both switches are in the TS position you have hazard flashers.
vicrod
Old 06-07-2012, 07:44 PM
That's a great schematic but I'm not using DPDT switches....
Old 06-07-2012, 08:35 PM
Why not. They are very inexpensive. If this solves your problem, why not buy 2 $8 switches?
Old 06-08-2012, 12:32 PM
I didn't use DPDT switches because I didn't have any on hand. I don't want to change them out just yet because the switches are in the dash and the dash is already put back in. I'd be looking at another 2-3 hours to get the dash out, changes switches etc. I may have to change over if the diodes don't work out but I'm not gonna do that first.
Old 06-08-2012, 08:00 PM
EOD Guy's Avatar
You could use your SP switches to fire some DP relays and acomplish the same thing. Are you using a single switch to control the L and R blinkers or two switches?
Old 06-09-2012, 10:06 PM
I'm using two switches, 1 for left one for right obviously. I'm curious now about the relays, how would those wire in?
Old 06-10-2012, 07:31 AM
EOD Guy's Avatar
They would wire in the place of the DPDT switches, in the above diagram, and your SP existing switches would fire the relay(s)......... Now if it were mine and I was going to use toggles for turn signals........... I'd use a single toggle, On-Off-On, to control four bosh type SPST relays. I'd use the bosh, due to the availability, cost and connecter ease
Old 06-10-2012, 11:31 AM
Hoptup32's Avatar
Here's a simple diagram using two bosch relays and two diodes with an on-off-on toggle switch. It could be easily modified to use two separate on-off toggle switches.
The 1N4001 diode is a 1-amp, which will probably work, or you could substitute a 1N5404 which is a 3-amp, which would be my preference. Both are available at Radio Shack.
Old 06-10-2012, 07:22 PM
EOD Guy's Avatar
I haven't tested this, so a bench mock up might be in order....... but I think this is the way I would do it. If anyone finds a flaw, please post.
One possible issue.....will the relay coils provide enough draw to let the flashers cycle properly, might have to use electronic flashers
Name:	turn signal.jpg
Old 06-12-2012, 02:58 PM
Very cool, Hoptup and EOD! These are great diagrams and it looks like I'll be changing out to the off-on-off switch set-up so the last switch on the panel can go to something else, prolly the trans cooler fan. Thanks again!
Old 06-12-2012, 04:14 PM
EOD Guy's Avatar
I'd do a bench mock up before I wired either into the car!
Trans brake switch showing small voltage, is switch bad? pdmracing Transmission - Rearend 1 09-26-2011 07:50 PM
1923 t-bucket brake lights and brake switch diagram kpost2 Electrical 7 09-15-2011 11:57 AM
Low Pressure Brake Switch Wiring tc33 Electrical 3 04-27-2010 09:34 AM
brake light switch wiring tjn Electrical 3 05-23-2009 08:01 PM
Brake light switch wiring... 38 special Electrical 10 09-15-2007 06:54 AM
