brake system help - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2009, 02:15 PM
brake system help
The vehicle is 1988 chevy K1500 4WH drive pickup light duty front disc brake, rear drum setup, stock calipers, master cylinder and proportioning valve.Here is the problem the wiring harness is cobbed to eliminate RWAL also the dump valve was bypassed and removed. In short the pedal has been soft all air is out rear shoes are adjusted up. Any suggestions on a different MC using just an adjustable proportioning valve on the rear drums only ? I believe the front calipers need a quick take up MC
Old 05-03-2009, 02:21 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
See if this recent thread will help w/your problems. It's HERE.
Old 05-04-2009, 04:03 AM
after reading that post it made me ask my question. OBD chevy brake issues has been beat to death yet no one has mention a MC that can make a difference in pedal firmness ( ss brake makes one like 300.00, stupid money for a MC ) has any trial and error different MC worked??
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 06:15 AM
whats the correct way to set up my brake system?? 60n68palaridin Suspension - Brakes - Steering 13 12-15-2007 03:25 AM
Charging system info............... poncho62 Electrical 11 11-26-2005 09:53 PM
Hydro Boost brake system BLOWN 1100 Suspension - Brakes - Steering 1 07-12-2004 01:23 PM
Regretting using silicone fluid - advice? Limey Simon Suspension - Brakes - Steering 3 04-30-2003 07:07 AM
