Is brake T on 9" rear threaded in?
I have striped the old brake lines from my 9" rear housing but left the "T" because I wasn't exactly sure how it comes off (no visible attachment). It also appears to be quite badly corroded so I'm leery about messing with it at all. Is this thing threaded into the housing and if I remove it will I have a hole I need to plug or do I need to get the exact Ford replacement T for some reason. I'm also wondering if this T provides some sort of venting for the housing.
Dewey
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod. |
Usually, the splitter (fitting) is held to the housing with the housing vent. What are you working on?
Might it be best just to leave the old one as it is? I figured I would use a new T and just hold it in place with a couple of weld on clips around the tubing coming off each end. I might try cleaning the original up this afternoon and shooting a couple close up pics so you can see what I'm talking about.
Post a picture if you can. The vents are readily available under FORD Basic PN 4022. The thread will be NPT. |
Turns out to be a case of asking a question before doing adequate investigation. If I had opened the box my new rear brake hose came in I would have seen my answer. The new hose comes with the splitter, and a pre drilled hole for the vent barb/attachment tube. Once I saw that I new the old splitter must be removable...and it was. The barb is actually a hollow bolt that goes all the way through the splitter and then threads right into the housing. So it was an easy off...easy on deal. But thanks for the guidance Kultulz.
At least you have a FORD rear in it...
Can you ever forgive me? ![]() It was your use of the word rat that scared me. I thought it was a BBC project. I have since cruised your project manual. Nice work. Last edited by KULTULZ; 03-30-2005 at 12:40 AM. |
| Where can I fnd a disc brake kit for jaguar rear end | Larry Tyner | Suspension - Brakes - Steering | 8 | 01-08-2010 01:50 PM |
| How much can a Versailles 9" rear handle? | newchevyman | Transmission - Rearend | 6 | 12-22-2004 05:54 AM |
| rear brake donor car for 70 chevelle | 68c10owner | Suspension - Brakes - Steering | 1 | 10-07-2004 01:47 AM |
| ford 9" rear housing for 70 camaro | richrat | Transmission - Rearend | 1 | 05-03-2003 10:56 PM |
| Ever had rear brake drums that refuse to come off? | JunkYardFrog | Suspension - Brakes - Steering | 23 | 01-12-2003 11:13 AM |
