Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - brake trouble
Thread: brake trouble
Old 06-15-2012, 12:25 AM
1pickup's Avatar
1pickup 1pickup is offline
Flathead Freak
My bro had this problem on his rat rod. The problem was that the pushrod for the master was TOO LONG. He had put an S10 setup in his '36 Plymouth. Apparently, the firewall was thinner on the car. Did you change anything else in this area? Adding a washer would probably be making it worse, unless you added them between the master & firewall.
