brake trouble - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-15-2012, 04:42 PM
Originally Posted by tommyboy8072002
Thanks 1pickup no i have not worked on anything else in this area. Thanks for the heads up i am going to see if i can find another booster in the mean time i am going to see if the parts store sell spacers. If you think of anything else let me know
Thanks Again
Felpro makes a Chevrolet thermostat gasket out of plasic with an O ring seal. Ir's the same bolt pattern as the master cylinder, and about .100" thick. You can use one of them as a spacer.
http://pitstopusa.com/i-5061702-fel-...ed-rubber.html
  #17 (permalink)
Old 06-18-2012, 05:52 PM
Ok I was just watching this show called Chasing Classic Cars last night and the same thing happened to them. So the cause for them was that the Master was bad and the booster locked up, they bleed the front brakes ONLY and it was good to go (except the brakes were out in the front). Might try that
  #18 (permalink)
Old 06-18-2012, 09:51 PM
brake trouble
Ok Thanks. If it does it again i will give that a try. What i ended up doing was using two thermostat gaskets in between the master and the booster and it hasn't done it yet. (knock on wood).
1923 t-bucket brake lights and brake switch diagram kpost2 Electrical 7 09-15-2011 11:57 AM
lets talk brake trouble fatchance2 Suspension - Brakes - Steering 3 06-26-2011 12:30 AM
Brake Booster Trouble.. pitts64 Suspension - Brakes - Steering 5 10-12-2010 03:40 PM
brake trouble 91 chevy 1500 alabamasho Suspension - Brakes - Steering 6 08-10-2008 05:05 PM
brake system trouble rb8179 Hotrodding Basics 7 04-25-2006 07:55 AM
