Notice the use of puctuation and capitols in the reply to the OP. Makes it easy to understand the problem and results in more helpful replies.. JMHO .
brake trouble
What about if i buy a proportion valve? And hook it up to the master cylinder to the front brakes. And the only one i can get is for a Buick car through Napa.
Would that work? Just wondering Thanks |
http://auto.howstuffworks.com/auto-p...ter-brake2.htm |
Changing brake line size will change nothing. Pressure on a hydraulic system is the same throughout the system regardless of line size.
Next time the brakes lock, open a bleeder in front. If they release the problem is the fluid is being held in the front, rather than released back to the master cylinder. The cause can be a misadjusted brake pedal, misadjusted booster pushrod, wrong master cylinder, something in the line acting as a check valve, or defective brake hoses. |
brake trouble
yup your right i opened the bleeder screw and it released
Thanks i will check the Hydro boost push rods and see what i can come up with i will also check the master cylinder to make sure that it was the right one for this truck Thanks again |
brake trouble
I have looked at the Hydro boost and i don't see any adjustments on the push rods does anyone know if i could put washers in between the master and the Hydro boost to make up the space so it wont keep doing this
Thanks |
My bro had this problem on his rat rod. The problem was that the pushrod for the master was TOO LONG. He had put an S10 setup in his '36 Plymouth. Apparently, the firewall was thinner on the car. Did you change anything else in this area? Adding a washer would probably be making it worse, unless you added them between the master & firewall.
brake trouble
Thanks 1pickup no i have not worked on anything else in this area. Thanks for the heads up i am going to see if i can find another booster in the mean time i am going to see if the parts store sell spacers. If you think of anything else let me know
Thanks Again |
| 1923 t-bucket brake lights and brake switch diagram | kpost2 | Electrical | 7 | 09-15-2011 11:57 AM |
| lets talk brake trouble | fatchance2 | Suspension - Brakes - Steering | 3 | 06-26-2011 12:30 AM |
| Brake Booster Trouble.. | pitts64 | Suspension - Brakes - Steering | 5 | 10-12-2010 03:40 PM |
| brake trouble 91 chevy 1500 | alabamasho | Suspension - Brakes - Steering | 6 | 08-10-2008 05:05 PM |
| brake system trouble | rb8179 | Hotrodding Basics | 7 | 04-25-2006 07:55 AM |
