brake trouble 91 chevy 1500 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-10-2008, 11:09 AM
hey friends I have a chevy truck thats eating brake pads on R-front changed caliper twice is it a block in the line or master cylinder thanks
Old 08-10-2008, 11:52 AM
yea there notorious for the rubber inside to form like a check valve , not releasing and wearing the pads out .
Old 08-10-2008, 12:01 PM
31 five window
Last journal entry: Moving along with patch panels.
Dead on.I had the same problem on my sons truck.
Old 08-10-2008, 12:23 PM
so which is it master or caliper , the new caliper is less than week old
Old 08-10-2008, 02:27 PM
47dodge's Avatar
Last journal entry: 1947 dodge
I had a car that did that. My problem was the rubber brake line that went to the caliper. They can look fine from the outside and be swelled shut on the inside. When you changed your caliper did fluid run out of the line pretty good or did you just get a couple drips?
Old 08-10-2008, 02:52 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Change your flex lines out on the front.
Old 08-10-2008, 05:05 PM
it leaked out pretty good, but i feel confident its a swelled line or blocked , thanks you guys give great advice.
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 05:15 AM
63 Chevy PU and 91 Burb 63CustomCab Hotrodding Basics 3 01-20-2008 08:28 PM
Engine build ideas Rug Engine 23 12-25-2006 01:39 PM
'85 Chevy El Caminos - Brake Problems? Margie Suspension - Brakes - Steering 6 09-21-2005 08:02 AM
350 in a '91 1500 chevy truck. bbogler Engine 0 09-18-2002 07:07 PM
