-   Hotrodders' Lounge (http://www.hotrodders.com/forum/hotrodders-lounge/)
-   -   Brake True? (http://www.hotrodders.com/forum/brake-true-15343.html)
5.0Towncar 01-27-2003 04:57 PM
Brake True?
I just saw a commercial for a product called "Brake True". It looks like a piece of rough grit sandpaper that is in the shape of a brake pad. What you do is, when you change your brakes you slip this product in between your disc rotor and your brake pad and it will "machine" your rotors for you when you apply the brake. But the commercial doesn't say if you are supposed to remove the "Brake True" after use, or even drive the car. I think this is a crap product to waste $19.95 on.Any ideas? Steve
4 Jaw Chuck 01-27-2003 06:31 PM
...one born every minute... :p
5.0Towncar 01-28-2003 04:13 AM
What? One moron? Steve
tm454 01-28-2003 04:20 AM
I'm not sure I understand how it would work. The pad/brake true will follow the conture of the rotor, maybe shine the rotor? Only cost about $10 to have a rotor turned when you buy the pads from a parts store that turns rotors.
Todd
5.0Towncar 01-28-2003 04:26 AM
Sounds like another Slick 50 commercial. Lets just spray water all over the inside of out engine!!! :D Steve
[ January 28, 2003: Message edited by: 5.0Towncar ]</p>
5.0Towncar 01-28-2003 04:30 AM
Also they said that it's soooo hard to remove the rotors, by the way it shows a man in his late 50's using a 3 foot pry bar trying to get the rotor off. the caliper was probably still bolted on. Steve
KULTULZ 01-28-2003 04:32 AM
If you order using your credit card in the next thirty minutes...you will recieve FREE two cans of of our famous Engine Compression... :D
5.0Towncar 01-28-2003 04:33 AM
LOL, what is it bottles of carbonated water? Steve
lookatme 01-28-2003 08:38 AM
Yeah and a set of ginsuu knives
meanmachine666 01-28-2003 08:45 AM
oh and do not forget the second set of brake true for you friend to try .
Yes not one set but two sets of brake true and a set of ginsuu knives plus if you order using your credit card in the next thirty minutes...you will recieve FREE two cans of of our famous Engine Compression all for the amazing low price of 19.95 plus S&H.
neil madsen 01-28-2003 10:29 AM
Now you can have all of this amazing produt with a value of 199.99 for ONLY 13.99.But if you call in the next 15 min you will recieve this gift for FREE....bla bla bla bla :rolleyes:
lookatme 01-28-2003 11:36 AM
With all this FREE crap how CAN I go wrong?
[ January 28, 2003: Message edited by: lookatme ]</p>
