brake/turn signals wire problems
54 ford f100
I have 4 wires at the rear bumper left turn,right turn, run lamp and brake light the new lights have 2 wire and 1 1157 lamp if i hook up the run light tho the low beam side and the 2 turn signal wires left and right what do i do with the brakes hooking them in with the turn signals will mess every ting up wont it HELP woody |
whatever you are using for a turn signal switch will have a brake input that wire you have is typically only for a 3rd brakelight or if it is straight from your pressure switch it goes to the signal switch
PS i created an account to answer your question |
if your using any after market wire system, i agree with lefty.
the turn indicators are also your brake lites. the brake lead will go to your 3rd brake lite. most turn lite switches have 2 hot feeds; keyed on and thru the brake switch. the bright element on the 1157 is turn/stop the smaller/dimmer filament is running |
A trailer can use three wire because the tung is the ground or return if you prefer, it is not a conversion. One reason trailer lights will start out not working and then a few turns later they will work. |
| Turn signals to brake/running lights conversion (motorcycle) | weirdbeard | Electrical | 3 | 08-08-2010 03:16 PM |
| 1963 cadillac brake lights and turn signals Help Please | colwoodshane | Electrical | 6 | 03-07-2010 01:24 PM |
| problems turn signals | 72steve | Electrical | 3 | 03-09-2009 03:28 PM |
| Problems with my turn signals and front lights | 74_Chevrolet | Electrical | 3 | 08-29-2005 11:14 PM |
| how to wire in the signals and brake light | Knobie | Electrical | 3 | 08-14-2003 06:30 PM |
