brake vacumn canister - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2008, 08:14 AM
When using a canister are both check valves used? one on booster other on canister inlet.
Old 09-14-2008, 08:24 AM
540z's Avatar
Brute force and ignorance.....
As long as they're both pointed in the same direction. In other words, if both valves allow engine vacuum into the chamber and the booster without letting it out.
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 05:15 AM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
power brake booster vacuum canister?? Ed ke6bnl Suspension - Brakes - Steering 1 10-21-2004 04:33 PM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
