Brake Vacuum Boost - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-10-2002, 09:21 AM
Post Brake Vacuum Boost
Is there a street-rodder out there who has used the GM vacuum boost pump and pressure switch (found on the older GM cars) in conjunction with the after market master cylinder with the 9" booster assembly? As there is no place on the booster to "plug in" the pressure switch, I'm at a loss as to how to mount the pressure switch in the system. Or is there a booster pump with a built-in pressure switch one could find at the bone yard?
