Brake vacuum booster ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-02-2012, 09:37 PM
Last journal entry: Finally some floor!
Pardon my lack of remembering, but it's probably been a good twenty years or so since I last worked on brakes to speak of. I took a basic GM disc/drum master cylinder w/boost off of my 33 Plymouth's firewall. I bought a nice new chrome 7" booster & disc/disc master cyl. ( The car has disc front / disc rear). I take the new pieces out of the boxes & find there are no instructions! I can get them all mounted up together, but my question is this: shouldn't the plunger in the booster stroke more than just about a half inch! I bench bled the master and it in strokes fine, so I checked the booster before I mate them and it only strokes maybe 1/2 inch! I looked into the outside of the booster & it has a star type lock ring in the end about 1/2" in. Is that just for shipping and keeping the diaphram, etc. in place until ready? I realize that vacuum helps to assist with the pedal pressure when applied, but shouldn't the booster be able to stroke as far as the master? Bob
Old 04-14-2012, 07:45 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Needs the vacuum to work. Ever try to stroke a brake pedal w/ engjne off? Gotta have vacuum.
Brake Booster Vacuum Connection david-b Engine 3 11-12-2010 12:25 PM
Brake booster vacuum leak 70 ElCam Suspension - Brakes - Steering 11 10-03-2010 11:30 PM
power brake booster vacuum canister?? Ed ke6bnl Suspension - Brakes - Steering 1 10-21-2004 04:33 PM
brake booster vacuum problem spankthru Engine 1 06-18-2003 07:57 PM
vacuum brake booster 48Man Suspension - Brakes - Steering 1 01-14-2003 06:10 AM
