Brake valves missing - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-09-2006, 09:55 AM
I took on a 47 Ford coupe 302cuin AOD trans. as a repair job for no rear brakes. I discover there is no metering or proprotioning valve in the system. And I verified the rear brakes are not activating. I'm thinking I could install a adjustable proportioning valve in the back, but I'm not sure about the metering valve for the front. Are there certian types you have to have?
JR
Old 08-09-2006, 10:13 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
JR
1) we don't know what braking system you have, front and rear, no guessing allowed.
2) if the rears are not working at all, that is the first consideration. Worry about the valves later.
Dual Master Cylinder Brake Pedal with Balance Bar iceman36 Suspension - Brakes - Steering 6 02-24-2006 12:55 PM
Taurus Brake Caliper...Slow Release. awbazar Suspension - Brakes - Steering 5 02-22-2006 04:33 PM
Swap Drum to Disk Brake Ratoflic Suspension - Brakes - Steering 8 02-17-2006 11:24 AM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
