Brake Work on a 14 bolt Full Floater - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2010, 06:32 PM
Can i lift the wheel up on one side of a 14 bolt full floating axle enough to not have to drain all the oil out of it so I can remove the drum?
Old 03-16-2010, 08:02 PM
Yes, but why? I regularly pull the axles on my duallies with the rear axle level. A small dribble of gear oil comes out. If oil is pouring out, the axle is overfilled.
Old 03-16-2010, 08:09 PM
Well, I think the gear oil keeps the wheel bearings lubricated, which means the oil would have to fill up 1/4" or so in the tube to keep oil to it. So I figure if i pull the axle out level or almost level it would leak out.
I dont want to drain the oil from it, but I do need to get one drum back off. I just did some brake work to it and realized i made a mistake on one side. Nothing serious, just a spring on the adjuster is not seated right, so the lever is not engaging the star wheel. I need to get that drum back off and fix it so the adjuster will work.
Old 03-16-2010, 08:15 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
You should be fine. My truck also has a full floating 14 bolt and I pull the axles out on occasion without much oil coming out while leaving both wheels on the ground. If you're really worried about it there is nothing wrong with jacking one side up.
Old 03-16-2010, 08:21 PM
Well i'll have to jack it up a little to get the drums off anyways, Just didn't know if i'd have to jack it up any higher than usual to keep the oil in.
Thanks for the help guys
14 bolt dually vs IH dually rear??? HemmiGremmie Transmission - Rearend 2 02-01-2010 08:49 PM
12 bolt or 14 bolt? steveyb4342 Transmission - Rearend 10 10-03-2007 05:17 AM
Brake lights wont work!!! stroked76 Electrical 2 10-15-2003 05:06 PM
14 10.5" bolt chevy VS 9" ford Trav Transmission - Rearend 4 09-01-2003 07:49 PM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
