Brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-04-2002, 07:48 AM
New Member
Post Brakes
It is decided that my 61 Falcon is getting a 77 MustangII front swap. I've done the swap several times with the 11" brakes. This car ways in at 1100 lbs less than the MII, I'm thinking the stock 9"brake should be quite adequate for the Falcon. Any thoughts, or advice?
Old 10-04-2002, 02:55 PM
johnnymopar's Avatar
Love your nails! You must be a Libra
Talking
just my opinion, but unless the 11" are going to cost more than you want to spend, i would go with 11". You are probably right that the 9" would work fine, but if you can have better performance than why not go for it? The only problem with better-than-average brakes is if somebody is behind you and they can't stop fast enough, but depending on what's in front, who knows, better brakes may save your life someday.
JB
"Well done is better than well said." - Benjamin Franklin (1706-1790)
