brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2003, 01:47 PM
Post brakes
I have a 1970 chevy truck and you can push the brand away down and it will not stop but you can push it lot and it will stop but not good. i put brake fuild in it. Do i have to pump it in the lines or do I need brake shoes. Drum brakes by the way.
Old 03-03-2003, 02:37 PM
72 chevy's Avatar
Post
Sounds like you have air in the system, youll need to bleed them, if that is the case. You should first pull the drums and inspect the shoes. I replace them when the linings are worn to 1/32" or less. I use a cheap plastic vernier caliper to measure linings, but a tape will work. If the shoes are shot, go ahead and take the drums to a good shop to see if they need to be turned, I had two drums turned at a local parts store for $15, cheap insurance. When thats all squared away, install em, adjust em, and bleed the system. Trust me on this, you want your brakes to work, you never know what may happen!! tips on bleeding brakes.
[ March 04, 2003: Message edited by: 72 chevy ]</p>
