Brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-13-2007, 02:37 PM
Last journal entry: 1950 chevy 3100 P/U
Brakes
I was wondering what i should do with the rear brakes on my 1950 chevy 3100 truck. first of all I am putting a small block 350 in and i am putting on a mustang II front end with air ride suspension. should i convert the back brakes over to disk or would the drum brakes be just as good.
Old 11-13-2007, 02:47 PM
Stock 1950 Chevrolet 3100 pickups have a enclosed driveshaft and will NOT work with a modern " open " driveshaft transmission ( such as a Turbo 350, Turbo 400, 700R4 , or a Muncie 4 speed ) . A more modern rear end is required ...
Disc brakes are nice ... and are fairly available ... both in OEM form or by after market conversion. I suggest a rear end with the correct width for the 3100 ... and with the same wheel bolt pattern as the brake rotors on your Mustang II/Pinto conversion.
disk brakes conversion no pressure to back brakes shiner Suspension - Brakes - Steering 10 01-24-2011 11:09 AM
Hotrodders Knowledge Base: Suspension - Brakes - Steering Jon Suspension - Brakes - Steering 0 11-26-2005 06:29 PM
Brakes DoubleVision Suspension - Brakes - Steering 2 11-11-2005 01:51 PM
G body with manual brakes - it works! - pics dh79 Suspension - Brakes - Steering 7 08-27-2005 10:55 PM
Brakes locking up in non ABS system nprfan Suspension - Brakes - Steering 9 08-24-2005 12:37 PM
