brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2008, 03:38 PM
brakes
i have a 1965 chevelle i want to put disc brakes on the front can i use the brakes from a 78 to 84 malibu and what else would need to be changed
Old 09-17-2008, 08:52 PM
GM changed the taper on the ball joint stud after 1972. The later spindles will physically bolt up but the tapered ball joints (and tie rod ends) will NOT be supported properly. You would need to change to the later ball joints and tie rod ends. The upper ball joints bolt in, but the lowers require machining to fit in the control arms. The tie rod ends require special sleeves to mate to the existing inners. Finally, the later spindles are taller, which can cause problems with alignment unless you use shorter aftermarket upper arms. By the time you do all of this, you might as well go with the B-body spindles and get 12" disks as well.
On the other hand, Speedway Motors has a factory-style A-body disk brake kit that's probably the least expensive one I've seen.
Old 09-17-2008, 09:16 PM
302 Z28's Avatar
What about pre 72 Olds Cutlass, Buick, Nova and such?
Vince
Old 09-18-2008, 10:25 AM
Vince
1964-72 A-body (Cutlass, Chevelle, LeMans, Skylark), 68-74 X-body (Nova and clones) and 67-69 F-body all use the same spindles and disk brakes. The steering arms are different but they bolt on so just use your old ones.
The problem is that restorers have driven up the prices of these disk brake sets. If you find an affordable set, jump on it.
Old 09-18-2008, 03:00 PM
brakes
joe can i possibly use 1974 camaro type spindels or is this the same issue ..i ask because i have a donor car .thanks for your help
Old 09-18-2008, 08:17 PM
Unfortunately it's the same problem with the ball joint taper and the spindle height differences. The 70-up F-body, 73-up A/G body, 75-up X-body, and 71-up B/C-body all use the same ball joint taper (and often the same ball joints), which is different from that on the earlier cars. The only bolt-in spindles are the ones I listed previously.
Old 09-19-2008, 12:10 PM
brakes
thanks for the input joe .i found a complete set for 350.00 dollars yesterday again thanks for the help
disk brakes conversion no pressure to back brakes shiner Suspension - Brakes - Steering 10 01-24-2011 12:09 PM
No brakes on my 55 chevy tri5ernie Suspension - Brakes - Steering 2 08-14-2006 11:38 AM
Hotrodders Knowledge Base: Suspension - Brakes - Steering Jon Suspension - Brakes - Steering 0 11-26-2005 07:29 PM
G body with manual brakes - it works! - pics dh79 Suspension - Brakes - Steering 7 08-27-2005 11:55 PM
Brakes locking up in non ABS system nprfan Suspension - Brakes - Steering 9 08-24-2005 01:37 PM
