Brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2009, 08:31 AM
Brakes
Hey I need help with my 54 mercury I would like to put dics brakes on the front they should be some other years that will interchange but I have no books to tell, can someone help me PLEASE Thanks
Old 01-29-2009, 08:36 AM
aka Duke of URL
This is going to hurt, so please bear with me...
You should be able to find changeover kits (mounting brackets) to hang GM calipers without having to change the spindles. The FORD sliding caliper is prone to hang on it's slides and the GM less prone as they slides on pins.
Now if you are a purist as I am, I can show you plans to machine brackets to hang FORD two piston calipers and they are on pins.
Old 02-04-2009, 10:46 AM
Someone told me that alot of ford parts will interchange with each other if you know which ones someone should have a interchange book somewhere I would think .I can get the parts from a junkyard a little cheaper than buying a kit Any help would be great THANKS!!!
disk brakes conversion no pressure to back brakes shiner Suspension - Brakes - Steering 10 01-24-2011 11:09 AM
Need Help With My Brakes S10 Racer Suspension - Brakes - Steering 4 01-18-2009 02:00 PM
Hotrodders Knowledge Base: Suspension - Brakes - Steering Jon Suspension - Brakes - Steering 0 11-26-2005 06:29 PM
G body with manual brakes - it works! - pics dh79 Suspension - Brakes - Steering 7 08-27-2005 10:55 PM
Brakes locking up in non ABS system nprfan Suspension - Brakes - Steering 9 08-24-2005 12:37 PM
