brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-08-2011, 06:59 AM
brakes
Does anyone know how to stop the ft. disk brake pads from making noise by clicking back and forth orrocking back and forth?
Old 03-08-2011, 07:02 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
What are you working on ? there is supposed to be a clip/anti rattle clip or something that helps hold them in place are you missing something ?
Cole
Old 03-08-2011, 07:09 AM
brakes
I have a 34 ford with wildwood disk fronts and they both rattle. there is a cotter pin in the middle, so i put one in each end and they still rattle till i touch the brake peddle.
Old 03-08-2011, 07:17 AM
brahes
hi cole. do you know wher that anti rattle clip gos?
Old 03-08-2011, 07:24 AM
eloc431962's Avatar
Wiki Edits: 37
I would contact the guy's here at wilwood . http://www.wilwood.com/ .click the link scroll down to the bottom of the page and contact a tech or one of the others.
Cole
Old 03-08-2011, 07:26 AM
brakes
Thanks cole, i will try that. Hemi.
Old 03-08-2011, 07:28 AM
eloc431962's Avatar
Wiki Edits: 37
Do you have this style brake pad on your set-up ?
Cole
Old 03-08-2011, 08:21 PM
Cape Cod Bob's Avatar
If you have under floor MC you need a residual pressure valve. If you don't that may be allowing the brake cylinders to retract and let the pads rattle. Just a thought.
Old 03-09-2011, 07:48 AM
eloc431962's Avatar
Wiki Edits: 37
AWWW this is true it could cause a problem.
Cole
disk brakes conversion no pressure to back brakes shiner Suspension - Brakes - Steering 10 01-24-2011 11:09 AM
rear end disks brakes that bolt up in place of drum brakes that has a 383 465hp engin calon Introduce Yourself 2 01-23-2011 06:52 PM
Power Brakes feel like Manual Brakes kbuhagiar Suspension - Brakes - Steering 13 09-10-2010 03:02 PM
Power boost drum brakes vs. disc brakes??? woodscavenger Hotrodding Basics 13 08-08-2007 02:07 PM
brakes new bleed evrything still no brakes master cylinder bad? IHAVECHEVYPARTS Suspension - Brakes - Steering 2 11-12-2002 08:09 PM
