brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2013, 02:09 PM
brakes
I have a 71 nova.It came with a 307 auto.I am refittting it with a 454, and a 5 speed trans.Can I keep the drum brakes?They are power assist,and all new parts will be used.Thank You
Old 02-11-2013, 02:59 PM
T-bucket23's Avatar
Wiki Edits: 26
Brake size requirements are based on vehicle weight. If it stops ok now it will be the same with the new engine. That Big Block is about 200LBS heavier than the Small Block which should have no impact on how the brakes work. Of course a disk upgrade will make a big difference on how the car stops. Drum brakes are susceptible to brake fade and water
if you drive it in the rain.
Chet
Old 02-11-2013, 03:01 PM
302 Z28's Avatar
I would at least upgrade to factory disc brakes. There are plenty of donor cars out there to get the required disc brake spindels from and you can buy new calipers and power booster/master cylinder. No way would I stick with drums.
Vince
Old 02-12-2013, 04:19 PM
Thank You!
disk brakes conversion no pressure to back brakes shiner Suspension - Brakes - Steering 10 01-24-2011 11:09 AM
rear end disks brakes that bolt up in place of drum brakes that has a 383 465hp engin calon Introduce Yourself 2 01-23-2011 06:52 PM
Power Brakes feel like Manual Brakes kbuhagiar Suspension - Brakes - Steering 13 09-10-2010 03:02 PM
Power boost drum brakes vs. disc brakes??? woodscavenger Hotrodding Basics 13 08-08-2007 02:07 PM
brakes new bleed evrything still no brakes master cylinder bad? IHAVECHEVYPARTS Suspension - Brakes - Steering 2 11-12-2002 08:09 PM
