Brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-10-2013, 12:03 AM
Brakes
I have a 57 chevy belair it has 4 wheel disc brakes off of a s10 p/u. IT HAD A POWER BRAKES BUT I WANT TO CHANGE IT TO MANUAL BRAKES .WHAT KIND OF MASTER CYLINDER DO I NEED? THANKS FOR ANY HELP!!
Old 08-10-2013, 08:04 AM
delawarebill's Avatar
brakes
is there a reason u can't pull the bladder off and use the m/c by itself ?? it's already good for what u have.. just wondering, since it's already setup of why u want to go back to manual's ??
Old 08-10-2013, 08:27 AM
Wiki Edits: 27
pedal ratio
You might want to use a manual brake pedal with the different ratio so you wont need to stand on it with both feet. manuals have more pedal feel and when drag racing some power brakes don't release fast enough.
Old 08-10-2013, 10:39 AM
S10xGN's Avatar
Gotta love a turbo!
As a rule, manual brakes need a higher pedal ratio (6.5:1 vs 4:1) and a smaller bore (1" or less) master with a deep piston cup so the pushrod won't fall out.
Russ
Old 08-10-2013, 10:51 AM
302 Z28's Avatar
Russ
Exactly, a Power MC is different than a manual MC. Use the proper MC for safety sake.
How it going Russ, still in SE Texas
Vince
Old 08-11-2013, 09:46 AM
S10xGN's Avatar
Gotta love a turbo!
Vince
Yup, I was able to retire at the end of 2010, so it's been a nice time in spite of the heat & humidity. At least you only have the heat to worry about!
Russ
disk brakes conversion no pressure to back brakes shiner Suspension - Brakes - Steering 10 01-24-2011 12:09 PM
rear end disks brakes that bolt up in place of drum brakes that has a 383 465hp engin calon Introduce Yourself 2 01-23-2011 07:52 PM
Power boost drum brakes vs. disc brakes??? woodscavenger Hotrodding Basics 13 08-08-2007 03:07 PM
Weight of Disc Brakes vs Drum Brakes leejoy Suspension - Brakes - Steering 7 06-29-2007 01:41 AM
brakes new bleed evrything still no brakes master cylinder bad? IHAVECHEVYPARTS Suspension - Brakes - Steering 2 11-12-2002 09:09 PM
