Brakes? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2004, 08:25 PM
Last journal entry: 1969 SS Camaro
Brakes?
I have had brake problems with my 1998 jeep cherokee,the brake pedal will almost touch the floor so I had it checked out and they told me it was the master cylinder.So I changed the master and the pedal is doing the same thing.This is a mail right hand drive jeep and I went to stop at a mail box and it just slid right past the box so thats when I notice the pedal almost touching the floor.If you guys can help me it would help me alot I need it have it ready by saturday.
Old 04-29-2004, 09:16 PM
dmc12mk3's Avatar
Last journal entry: Fixed some leaks
Just to avoid assumptions, you have plenty of fluid in your resevoir and have bled the brakes?
Also, you do not have a line loose that is spraying fluid everywhere or possibly a wheel cylinder that is leaking? If it a wheel cylinder you'll see some white spots slung around on the inside of the tire where you have the trouble.
edit - abs by chance?
Old 04-29-2004, 09:21 PM
Yes I have bleed all 4 wheels got the air out and filled up the resivor,and its has abs on it.
Old 04-29-2004, 09:29 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
White spots???
Are the rear brakes adjusted properly (front ones too if drum)?
Emergency brake not working, or engaging at almost full travel is a good indicator of shoes out of adjustment.
This is the most common cause, due to automatic/self adjusters being froze up and not doing their job.
Is the ABS light on?
I just noticed you said 1998.......I guess you don't have drums on front anyway......
Do you even have them on back?
Old 04-30-2004, 09:53 PM
dmc12mk3's Avatar
Originally posted by BstMech
White spots???
My Chevy had a leaking wheel cylinder. I was searching for the leak that was going on with my brakes and I noticed that particular tire had white looking stains where the fluid had dripped on it.
Old 04-30-2004, 10:27 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Wierd.......it wasn't a whitewall turned in and the fluid was making clean spots on the white was it?
I thought it might have been a typo for "wet" spots.
Old 05-01-2004, 06:52 AM
adtkart@aol.com
I am not much up on ABS, but understand that on some systems there is a specific way to bleed them. Also, did you bench bleed the M/C? If the pedal feels spongy when it goes that far down, it is likely air in the system. If it is hard, check the adjustment and condition of the pads/ shoes. The rod for the M/C may not be adjusted properly. Also may be a bad reman M/C.
