Brakes for a 42'-47' Ford Dropped Axle - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-27-2006, 11:52 AM
ATX30Sedan's Avatar
Hi All,
I've got a 42-47 Ford dropped axle front end and I'm trying to find out what rotors will fit on these spindles. I know the Wilwood kit will fit on these, but I would like to keep things a bit cheaper. Not sure what applications will fit...or what year/s and make will fit. Any help or direction would be great.
Nick
Old 03-04-2006, 01:46 PM
Lots of companies sells kits for those spindles.
You can adapt GM pattern or Ford Pattern rotors to the 42 to 48 Ford spindles......easily......
Speedway sells kits.......
http://www.speedwaymotors.com/xq/asp...tLargeView.htm
9 inch ford home made disc brakes zonk Suspension - Brakes - Steering 6 06-02-2006 12:31 PM
Disc brakes for Ford 9" S10xGN Suspension - Brakes - Steering 12 11-25-2005 06:19 PM
Looking at project cars, 42 chevy, 55 desoto, 59 ford truck among others Wmarden Hotrodders' Lounge 8 02-08-2005 05:19 PM
Ford Explorer Rear Disc Brakes Lloyd Topping Jr Transmission - Rearend 4 11-10-2002 02:06 PM
8" Ford rear Axle Ron Fowler Suspension - Brakes - Steering 7 04-26-2002 09:20 PM
