brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2003, 09:59 AM
Post brakes
im redoing my 383 chevelle after puting on my intake and noticed that my new carb doesnt have a vacume port for my brakes i have one on my carb spacer for pcv .can i just plum into my intake for vacume or put anouther port in my spacer one for pcv and one for brakes .my intake is a rpm and my carb is a holly hp is there somwere else i can grab vacume from ??
Old 01-26-2003, 01:01 PM
aka Duke of URL
Thumbs up
Yes...
Try to tap into the main plenum rather than a single runner so as not too upset the balance of the individual runners.
Old 01-26-2003, 05:57 PM
Post
i saw a pluged hole about 1 inch behind my carb base do u think i could tap into that
Old 01-26-2003, 06:06 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
You can do that, but I would rather plumb the spacer with nipple/fitting. Brakes- rear side of spacer. PCV- front side. That's the way the factory routed'em.
