Brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-04-2005, 03:55 PM
Brakes
I'm in the process of frame off 79 Malibu,I've added disk brakes to rear with 9"ford rear end.My question is should I change proportioning valve since car had drums on rear before??????
Old 12-04-2005, 04:22 PM
poncho62's Avatar
Wiki Edits: 5
And a master cylinder that is valved for disk/disk...................
Old 12-04-2005, 04:52 PM
How would you go about finding out which would work??? Master cyl.& proprotioning valve
Old 12-05-2005, 06:22 AM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
www.mpbrakes.com has the proportioning valves.
With discs on front and rear you can run WITHOUT a proportioning valve, but need a junction block with the brake light switch (like drum brake cars, which also have no proportioning valve). When you have like brakes front and rear the rear brakes are usually designed to have less "grab" than the fronts, hence no valve needed. On a Jaguar, for example, solid rotors with two piston calipers are on the back, big vented rotors with four piston calipers are on the front (I run a Jag rear axle w/stock calipers, and checked the front out when pulling the rear).
On a custom installation this isn't necessarily so, so most people will run a proportioning valve to ballance out the system. Most people will run a standard GM disc/disc proportioning valve which will give some balance, or you can put an adjustable valve in the rear line. The stock drum valve will work, it just may not let enough pressure go to the rear brakes. The brakes will still operate, just not as well as they could. Proportioning valves limit pressure to 200-400 psi for drum brakes. All I know for sure are AMC application pressure. The Javelin (similar size to Mustang and Camaro, circa 1970-73), Hornet, and even Gremlin used a 200 psi valve, the big cars (Matador and Ambassador, comparable to a late 60s Chevelle and Impala) used a 400 psi valve. Again, those pressures were with drum brakes.
The only way to find out if your pressure valve is set right it to go to a wet parking lot, sprint up to 45-50, then slam on the brakes. If all four lock you're set right. After locking though, make some more runs with less pedal pressure. What you're trying to do is see if there is a point that the rear brakes lock before the fronts. You might try it a bit faster, but make SURE you have plenty of room in that (EMPTY) parking lot! With the weather like it is, I'll add that you want WATER -- not ice! What you're looking for is the rear brakes to lock about the same time as the fronts or only slightly before or after. If they lock to much before the fronts the back end will slide around unless you're perfectly straight. If they lock only SLIGHTLY before the fronts they will give you a warning that the fronts are about to lock and you can pump or let slightly off the pedal. If the fronts lock SLIGHTLY before the rears you're close to maximizing rear brake potential. If they NEVER lock (but the fronts do) you're losing a lot fo braking potential.
The important thing is to make sure the residual pressure valve is out of the master cylinder if using a drum brake master. The reservoir size doesn't matter -- the big reservoir is used because the piston in a caliper doesn't fully retract like the pistons in a drum brake wheel cylinder. So the fluid level gradually decreases. The big reservoir was an attempt to "idiot proof" the front discs -- there's enough fluid in there to safely operate the front brakes for the life of the pads if you never check fluid level. So you can use the drum brake master IF the bore size is correct for the calipers you have. Check the bore size for the vehicle the rear calipers came from. The wrong bore size can affect braking power! Note that later GMs (started in the 90s) have stepped bore master cylinders -- the front and rear portions use different bores. Unless you're sure about the bore, change the master cylinder to one made for disc/disc operation. That's the safest way to go!
Here's a good question -- what's more important, going fast or stopping?? To many people upgrade engines and leave the same old brakes in a car. This is especially dangerous for older sixties and early seventies cars with what could be considered marginal brakes using today's standards.
Old 12-05-2005, 11:52 AM
poncho62's Avatar
Wiki Edits: 5
farna...Where is the residual valve in the disk/drum MC, and how is it removed?
just asking for future referance.
Old 12-05-2005, 01:36 PM
farna's Avatar
Wiki Edits: 14
Most master cylinders have the residual valve under the tubing seat of the rear (drum) brake section -- the smaller reservoir. I usually stick screw in the small hole of the tubing seat and pull it out with a pair of pliers (or a claw hammer if the screw is the right length). A small spring and piece of black hard rubber or plastic should come out. Might have to slightly tap the pedal to get it to pop out, but I've only had to do that on a master cylinder that sat up a while. Put the tubing seat back in once the valve is removed.
Old 12-05-2005, 04:28 PM
Thanks Farna for all the info.I'm using stock GM metric calipers on front and rear,I think I'll try and remove the residual from the master and try that 1st.again Thanks a ton.
Also thanks Poncho62 for asking the right question.
Old 12-06-2005, 07:02 AM
farna's Avatar
Wiki Edits: 14
AMC used GM calipers late in the game too, so I can tell you a little something about them! They used Bendix calipers (which are the same size) before going to the GMs in 82.
The 82-83 GM calipers have a 2.6" (66 mm) piston diameter (measured from the outside edge of the piston). You should be able to measure it "close enough" with a tape and without removing the dust cover. The inside diameter of the piston is somewhere around 2.3" (58 mm). If that's the size caliper you have, you need a 1" bore master cylinder (25.4 mm). You'll be fine if slightly more or less, like in the 0.895-1.08" range (23-27 mm). The big 3.1" (78.7 mm)piston calipers AMC used on their big cars require a 1-1/8" bore master cylinder.
In the early 70s US manufacturers made non-power front disc brake cars. Now those require a bit more foot effort than non-power drums -- I've driven small cars (Hornet, Gremlin, and my old 63 American conversion) with non-power front discs. A little more effort than the old drums, but not bad. The big cars were another story. AMC used a 1-1/6" bore master on the big non-power front disc cars. Reduce the bore of the master cylinder and you increase pressure, but decrease volume, for the same amount of stroke. There was about 3/4" more pedal travel (1/8" more master cylinder stroke) to make up for the volume. What I don't know is if the master was "special" for this application other than bore size (special as in made different to allow the stroke increase).
disk brakes conversion no pressure to back brakes shiner Suspension - Brakes - Steering 10 01-24-2011 11:09 AM
Hotrodders Knowledge Base: Suspension - Brakes - Steering Jon Suspension - Brakes - Steering 0 11-26-2005 06:29 PM
Brakes DoubleVision Suspension - Brakes - Steering 2 11-11-2005 01:51 PM
G body with manual brakes - it works! - pics dh79 Suspension - Brakes - Steering 7 08-27-2005 10:55 PM
Brakes locking up in non ABS system nprfan Suspension - Brakes - Steering 9 08-24-2005 12:37 PM
