Brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-09-2006, 09:31 AM
Brakes
I'm JR and I am a OEM mechanic that is working on a 47 Ford street rod for a guy with brake problems. I have question.
Old 08-09-2006, 09:35 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
So??????Whats the Question???????
Old 08-09-2006, 12:43 PM
Originally Posted by jreaton535@yahoo.com
I took on a 47 Ford coupe 302cuin AOD trans. as a repair job for no rear brakes. I discover there is no metering or proprotioning valve in the system. And I verified the rear brakes are not activating enough to stop. I'm thinking I could install a adjustable proportioning valve in the back, but I'm not sure about the metering valve for the front. Are there certian types you have to have?
JR
Old 08-09-2006, 12:51 PM
Wiki Edits: 31
well, if you add a prop valve you will decrease the amount of preassure going to the rear brakes, that is not what you want to do. I'd start by turning in the ajusters and go from there.
Old 08-10-2006, 09:07 AM
This is not the psychic hotrod network. In order to answer your questions we need some info. How about starting with what type, size, make, of brakes are front and rear as well as the master cylinder.
Old 08-10-2006, 09:27 AM
302 Z28's Avatar
I agree with Matt, a prop valve is only going to make the problem worse not better. You need to find out if the master cylinder is outputting enough pressure to the rear. Does it have a dual master cylinder? Does it have a prop valve assembly at the master cylinder?
Vince
Old 08-10-2006, 10:39 AM
Lost in the 60's
Wiki Edits: 4
It could be that you have the lines hooked up to the master cyl in reverse.
disk brakes conversion no pressure to back brakes shiner Suspension - Brakes - Steering 10 01-24-2011 11:09 AM
Hotrodders Knowledge Base: Suspension - Brakes - Steering Jon Suspension - Brakes - Steering 0 11-26-2005 06:29 PM
Brakes DoubleVision Suspension - Brakes - Steering 2 11-11-2005 01:51 PM
G body with manual brakes - it works! - pics dh79 Suspension - Brakes - Steering 7 08-27-2005 10:55 PM
Brakes locking up in non ABS system nprfan Suspension - Brakes - Steering 9 08-24-2005 12:37 PM
