Brakes appling themselves Help - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-23-2012, 08:32 PM
65G10's Avatar
Mine will "pump" up tight also , but I know I have the rod between the pedal and MC adjusted super close. I can get it to release fully with a toe pull on the pedal,No Booster on mine. Usually going a small distance down the road will allow the normal knock back from the rotors against the pads to release things. . Are you using an aftermarket below the floor setup or thru the firewall ? Sometimes these 4 wheel conversions get a little glitchy. Have you put it up on stands to see if it is effecting both front and rear or just one end ? The Master cylinder has to fully comeback to release. if pulling it back releases the brakes then it has to be in the linkage or MC and even a slight failure to return will create the pump up . Maybe some pics of the pedal to Booster setup would help.
disk brakes conversion no pressure to back brakes shiner Suspension - Brakes - Steering 10 01-24-2011 11:09 AM
rear end disks brakes that bolt up in place of drum brakes that has a 383 465hp engin calon Introduce Yourself 2 01-23-2011 06:52 PM
Removing/appling trim + adhesives Finaltheorem47 Body - Exterior 3 04-06-2009 12:04 AM
Power boost drum brakes vs. disc brakes??? woodscavenger Hotrodding Basics 13 08-08-2007 02:07 PM
brakes new bleed evrything still no brakes master cylinder bad? IHAVECHEVYPARTS Suspension - Brakes - Steering 2 11-12-2002 08:09 PM
