Brakes appling themselves Help
I have a 57 Studebaker pickup with 4 wheel disc brakes I recently purchased. It had a leaking brake booster that I replaced. Then the problems started. Ocassionally the brakes don't release when applied and the pedal doesn't reurn all the way back. If I pull the pedal back with my hand then the brakes release. Also the brakes will apply themselves and again if I pull the pedal back they release. I have added a strong return spring on the pedal with no results. Clearance between booster and master cylinder has been checked and gives about 1/4 inch freeplay. I checked the m/c and fluid was overflowing and I reduced it to about 1 inch below the top with no resulting change. Any ideas
Maybe something here.
Classic Chevy, Chevrolet, GMC, Ford technical articles |
Sounds like a defective booster since the problem started after replacing it. Was the booster new or used?
heat build up ?
My son had a nash Metro that we swapped in a 1600 pinto and 4 spd, the brake lines were too close to the exhaust, boil the fluid ,
New booster. Why do you think it's the booster other than it being replaced? I did the booster tests shown on a link in this post and it checked out
Are you running residual valves ? If the MC resevoir is higher than the calipers by quite a bit it can prevent them from releasing correctly. Combine this with a small amount of heat build up it can cause intermittent braking pressure. I cannot remember the particulars , but I know of at least one case where a NEW booster was at fault. Is the pedal to booster connection allowing a complete return? Just ideas.
I believe the booster pushrod to the master cylinder is out of adjustment, or the pushrod from the pedal to the booster is out of adjustment, IE. too long in both cases.
I have now learned I can duplicate the problem at will. I start the truck and put in in gear. I keep tapping the brakes to keep the truck from moving and on about the 5th brake application they fail to release and I can tell that with each brake application from the beginning the brakes release less and less. After they fail to release I just pull up on the pedal and the truck starts to move. |
Doesn't make sense it will release when you pull the pedal up by hand but not when it's pulled up with a spring.
| All times are GMT -6. The time now is 09:07 AM. |
