brakes arent working right
ok my brakes arent working properly and im losing brake fluid out of the reservoir. ive lost a decent amount these past few days.i have a new master cylinder and a new reservoir on it and its still messed up. whats wierd is i went on vacation for 2 weeks and when i got back the brakes were working like normal but just started messing up again recently. and there seems to be fluid on the steering column not on the inside of the car but the part under the hood. so where is it leaking from? its unsafe and annoying because this is my daily driver. all your help is greatly appreciated. thank you
Artificial Intelligence is no match for Natural Stupidity Chet |
The fluid on the steering column or shaft under the hood is likely just from brake fluid leaking then dripping from some point- onto the steering parts. Do what T-bucket23 said, about drying off the MC- and see if the fittings or the grommets/seals are leaking. Be sure you don't let the MC run out of fluid until you find the problem. |
| anti-lock brakes | helrazr3 | Suspension - Brakes - Steering | 3 | 10-20-2007 01:06 PM |
| Bleeding brakes (possible bad booster or master?) | RippinRon | Suspension - Brakes - Steering | 2 | 03-29-2007 06:16 PM |
| No brakes on my 55 chevy | tri5ernie | Suspension - Brakes - Steering | 2 | 08-14-2006 10:38 AM |
| Ford PU brakes | adron s. | Suspension - Brakes - Steering | 5 | 04-01-2006 09:58 AM |
| Drum brakes smelling bad | nitsud08 | Suspension - Brakes - Steering | 5 | 04-11-2005 05:15 AM |
