are you tightening down the bleeders? What was the original reason that you bleed the brakes?
a worn wheel cylinder can pull air back into the system
find the wheel you are getting all the air from then start looking. A brake rotor that wobbles, check broken or loose wheel bearing can do that also
2rd the wheel brake cylinders..just had that problem on my truck..turned out to be a leaking brake cylinder
Fluid leaking out can be an indication that air is getting back in. I had an old merc with a caliper that needed bleed right after I bought it. Bleed it a day later same thing, only then it was leaking.
I saw a service bulletin about chryslers ABS modulator/valve assembly allowing air into the system,might be the issue. If the air comes out of a cylinder pretty much as soon as you open the bleeder then that cylinder/caliper would be suspect.If you have to bleed the fluid a bit before the air comes out then it is coming form somewhere upstream. The Master cylinder primary bore seal can leak air in and not have fluid coming out, also it could leak out into the brake booster and you wouldnt see it. I had one with a booster half full of fluid as the owner was adding and it was dissapearing, until his booster quit supplying boost, then when pulling the master looking into the booster I noticed it was half full of brake fluid. |
I totally forgot i made this thread
thanks for the responces! Still has the problem though.... Replaced the bleeder screws since it was cheap and hoped it might help, but nothing. The booster is bad though so i have to get that replaced. Should i just get the booster and master cylinder combo? Since it all has to be apart anyway i figured ot would be good to replace it. It does always look wet though.. Weird.
| Steering leak where rubber line meets metal line | bigdog7373 | Suspension - Brakes - Steering | 2 | 06-24-2011 07:26 PM |
| Best fine-line tape and tips to make a perfect line. | smithkustoms | Body - Exterior | 9 | 03-24-2010 11:29 AM |
| 3/8" female to male flex line needed. Any cars front wheel cylinder frame line? | Ripped | Suspension - Brakes - Steering | 2 | 03-12-2008 02:47 PM |
| Copper Brake Line,Fuel Line | redlightning | General Rodding Tech | 6 | 08-23-2006 08:50 PM |
| FUEL LINE & TRANS LINE SIZE/TYPE | leejoy | Hotrodding Basics | 7 | 11-29-2005 10:59 PM |
