Brakes lines usa to metric - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-29-2004, 09:12 AM
brainsboy's Avatar
brains
Do you guys know if anyone makes adapters for brake lines from metric to standard? I have a pontiac Fiero master cylinder which is metric and 84 Cadillac calipers which are standard.
Ben
Old 10-29-2004, 10:20 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Tooling
It might be the ticket to look for the tooling to cut and flare brake lines and make a line with the Pontiac fitting on one end and the Caddy fitting on the other end..Or does that make 2 much sense..maybe there is a parts store in your area that makes up brke lines and they could do this for you..
Old 10-29-2004, 11:36 AM
brainsboy's Avatar
brains
That certainly makes sense, but I wasnt sure if making my own ends would be as safe as pre-molded ends. I just didnt want to take any shortcuts in this area.
Ben
Old 10-29-2004, 11:53 AM
Wiki Edits: 3
Proper tools
I think it is a matter of having the proper tools for the job at hand and the confidence to do it..we do make up lines all the time for replacements..
Now the cheapy tubing flare tool probably will not do ..you will need to get the correct tooling for this job..course once you have the tooling you will never have to buy a premade brake line again..Grinn..
Brake lines use a double flare so do your shooping at the usual suspects for that type of tool..
practice a bit untill you get a good crimp on the flares and you should be fine..
Old 10-29-2004, 11:59 AM
brainsboy's Avatar
brains
I think the tools I have are for single flares. I will goto a local machine shop store and find what your talking about. Thanks for the info on it.
Ben
