Brakes Locked - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-04-2009, 10:34 AM
bosco200's Avatar
Brakes Locked
Ok my brakes are drum brakes and I am getting new lines for the back brakes so I have the lines off and I have the line that goes to the back brakes pinched off and I drove it through yard the other day and I just used the Emergency brakes and yesterday I moved it and I peeled out a little bit. So I parked it and later when I went to move it again I just kept on spinning and The front breaks are lcked up and I dont know why, how do I fix this.
Old 08-05-2009, 08:17 AM
Last journal entry: 50 Ply wagon
Take off the MC cover, and stick a screwdriver between the pad and piston on the caliper. Gently pry back the piston, but it will also push fluid back up into the MC, so you may want to draw some fluid out before you even start. Then,PLEASE!!! put all the lines back on the car and get ALL the brakes working before you hurt yourself or someone else. Not safe at all driving with just front brakes, even in your yard.
Old 08-05-2009, 10:33 AM
bosco200's Avatar
Yes I know and Thanks.
Old 08-07-2009, 12:28 PM
bosco200's Avatar
Ok my drum breaks are weird, ok so there were locked up, I tapped the break on the back of it where the break lines goes into the break with a hammer and the break freed up really good then while it ws spinning I pushed in the break pedal and the wheel stopped so I go to turn it and the wheel is locked up really bad again I can't figure this thing out????
disk brakes conversion no pressure to back brakes shiner Suspension - Brakes - Steering 10 01-24-2011 11:09 AM
Need Help With My Brakes S10 Racer Suspension - Brakes - Steering 4 01-18-2009 02:00 PM
Hotrodders Knowledge Base: Suspension - Brakes - Steering Jon Suspension - Brakes - Steering 0 11-26-2005 06:29 PM
G body with manual brakes - it works! - pics dh79 Suspension - Brakes - Steering 7 08-27-2005 10:55 PM
Brakes locking up in non ABS system nprfan Suspension - Brakes - Steering 9 08-24-2005 12:37 PM
