Thanks for the responses.
After deciding not to build a better mouse trap I added some gussets.. 2 good sized and 4 smaller to help in the twisting. I fixed the leak in the combo valve and have ordered more aggressive pads. . |
the bracket looks like it will be good to go
should be a lot better now which pads did you order? |
Bob, if after all this, and you are not satisfied with your stopping power, it is easy to buy the front brake conversion kit offered by numerous vendors. You have a few options with the two most popular ones being an 11 inch rotor that is drilled for either a 5 on 4.75 (GM) or for the Ford bolt pattern. The kit includes the bearings and seal to adapt the mid 80s Gm hub/rotor to your M II spindle and the mounting hardware and bracket for the GM 11 inch caliper. You will need residual valves and probably an adjustable proportioning valve.
Trees |
OK, so I got the beefed up brake bracket back on and there is now no more twisting when pushing the brake pedal. That give the pedal a better feel. I had my wife help me bleed them but is just not the same as having a full grown man help me. She is only 100 lbs. and 5' tall. LOL So, I could not get ALL the air out. The pedal is a lot better feel. Took her out for a drive to try out the new pads. The weather has been good to us here on thge cape.
There is improvement but not as much as I had hoped. Just need to get the air out . Even though I tightened up the metering valve nut on the end of the combo valve I am still seeing wetness there. Not showing up on the floor after bleeding though. Will watch that. After crusing around for a while and hitting the brakes hard I went back home and decided to be sure the brake lights worked and they didn't. Don't know what made me check them, just a hunch. Found the pressure switch bad and got a new one at NAPA. I don't know how they can make that switch so inexpensive $12.I'd rather pay double and have one that lasts.I only got 4000 mikles on the old one. Anyway , Its back up on blocks for tyhe winter. We are heading to Tampa for the rest of the winter on friday. Thanks for the advice and listening, Bob. |
sounds like you are getting closer
| Power Brakes feel like Manual Brakes | kbuhagiar | Suspension - Brakes - Steering | 13 | 09-10-2010 03:02 PM |
| manual brakes | ssonny34@yahoo.com | Suspension - Brakes - Steering | 9 | 08-02-2009 08:21 PM |
| Manual brakes | tommer2 | Suspension - Brakes - Steering | 4 | 03-10-2009 11:37 PM |
| Do I have power or manual brakes? | BRSleeper2 | Suspension - Brakes - Steering | 14 | 09-12-2008 05:30 AM |
| power brakes or manual | loud | Suspension - Brakes - Steering | 1 | 06-17-2006 12:50 AM |
