HOTRODDERS HELP!!!!
i got a 30 olds 5 window coupe
running a 65 389. approx 400 hp
im running a late 60's GM brake set up.
master cylinder is mounted under the floor
10 psi residual valve mounted on rear for drum brakes.
2 psi residual valve for front w/ disc brakes.
...my problem: front brakes seem to be slightly engauged when off brakes.
what i think is the issue: the fluid being stopped by said residual valve keeping pressure on calipers....
whats the solution?
whats the solution?
