Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - brakes not releasing on one side
Old 10-08-2012, 03:10 PM
66GMC's Avatar
66GMC 66GMC is offline
Get in, sit down, hang on
Last journal entry: Cab Removal
Front Brakes or Rear?
On the front (disc brakes) ... it's likely a caliper problem. Are the pads worn equally on both sides of the rotor (inboard pad / outboard pad)?
On the rear (drum brakes), look for a leaking oil seal, de-laminated friction material, and ALL brake hardware.
