Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - brakes not releasing on one side
Old 10-08-2012, 03:16 PM
T-bucket23's Avatar
T-bucket23 T-bucket23 is offline
Wiki Edits: 26
Bad rubber line maybe. this is common. if you can duplicate the problem. Jack it up pull the wheel and loosen the bleeder and see if it releases. If it does most likely the rubber line is collapsed. If not it could be the caliper. You can accomplish a similar test by cracking the line at the master. If it releases then your master cylinder rod may be adjusted to long.
Chet
