brakes not releasing on one side - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-08-2012, 02:54 PM
having trouble with my 86 silverado 2wd truck, the brakes on the passenger side will not release once applied, ive changed the brakes and bleed brakes. theres no air in the lines,but the brake still wont release, if the truck sits for awhile the brake will release. dont think lines are colapsed. can anyone help thanks so much
Old 10-08-2012, 03:10 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Front Brakes or Rear?
On the front (disc brakes) ... it's likely a caliper problem. Are the pads worn equally on both sides of the rotor (inboard pad / outboard pad)?
On the rear (drum brakes), look for a leaking oil seal, de-laminated friction material, and ALL brake hardware.
Old 10-08-2012, 04:16 PM
T-bucket23's Avatar
Wiki Edits: 26
Bad rubber line maybe. this is common. if you can duplicate the problem. Jack it up pull the wheel and loosen the bleeder and see if it releases. If it does most likely the rubber line is collapsed. If not it could be the caliper. You can accomplish a similar test by cracking the line at the master. If it releases then your master cylinder rod may be adjusted to long.
Chet
Old 10-08-2012, 05:25 PM
tried to remove the line, super hard to remove,it will release if you bleed it at the calpier. how do you know if the master cylinder is going bad,?
Old 10-08-2012, 07:30 PM
brake lock up
replace the brake hose
Old 10-08-2012, 07:50 PM
T-bucket23's Avatar
Wiki Edits: 26
x2 :d
Chet
Old 10-12-2012, 06:30 AM
Last journal entry: was hoping for better than this
replace both sides (hose)
Hydraboost brakes releasing slowly at drag strip?? iambigperm Suspension - Brakes - Steering 3 08-23-2010 12:16 PM
HELP brakes not releasing all the way dawg Suspension - Brakes - Steering 1 04-21-2007 01:18 PM
left side brakes wont work racur96 Suspension - Brakes - Steering 1 07-22-2006 04:32 PM
Frnt L. brake not releasing...? crazie Suspension - Brakes - Steering 3 08-05-2004 05:38 AM
Clutch not releasing Chevy Thunder2 Transmission - Rearend 4 01-05-2004 06:10 PM
