brakes pull to right - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-19-2005, 09:57 PM
New Member
I have a 1978 Chev 4x4 short box 350/350 combo. When I bought the truck it pulled to the right when you hit the brakes. I replaced both calipers, had the brakes power bled at a local shop, and it still pulls to the right. Any ideas?
Old 09-19-2005, 10:05 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Sounds like the rubber hose on the right side may be bad....They break down inside sometimes and a small piece of rubber could have come loose inside acting like a flapper valve and not letting the fluid return, thus keeping a little extra pressure on the right caliper.
Old 09-19-2005, 10:28 PM
Originally Posted by Jim Vines
Any ideas?
alignments off.
Old 09-20-2005, 07:45 AM
73oldsman's Avatar
Check "66 Nova Brakes" by Nettio, same forum, dated 9-09-2005 for his experience with his braking system for ideas. It may help!
Old 09-20-2005, 11:59 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Bad shocks will do it to. Especially if it's a timed. It'll pull for a second then stop pulling under even brake pressure.
Old 09-20-2005, 12:53 PM
poncho62's Avatar
Wiki Edits: 5
I agree with the hoses....replace them both.
Old 09-20-2005, 01:03 PM
35chev/302gmc's Avatar
worn front end parts
I would check the front end, you could have worn parts
1935 chevy,masters
disk brakes conversion no pressure to back brakes shiner Suspension - Brakes - Steering 10 01-24-2011 12:09 PM
G body with manual brakes - it works! - pics dh79 Suspension - Brakes - Steering 7 08-27-2005 11:55 PM
Brakes locking up in non ABS system nprfan Suspension - Brakes - Steering 9 08-24-2005 01:37 PM
Alignment problem 85 SS Suspension - Brakes - Steering 4 12-22-2003 04:02 PM
Brakes Pull Car to the Left 454impala69 Suspension - Brakes - Steering 2 05-17-2002 04:17 PM
